Viewing 10 posts - 1 through 10 (of 10 total)
  • #789
    brock
    Hey guys.
    Firstly – just wanted to say that I’m loving the DMD2 and adventure controller!
    One small issue I’m having is that the ‘plus’ button doesn’t seem to zoom the map in, in fact it doesn’t appear to have any action. The ‘minus’ button zooms the map out, and everything else seems to work normally.
    Am I missing something simple here?
    Thanks, Brock.
    #791
    Hey guys. Firstly – just wanted to say that I’m loving the DMD2 and adventure controller! One small issue I’m having is that the ‘plus’ button doesn’t seem to zoom the map in, in fact it doesn’t appear to have any action. The ‘minus’ button zooms the map out, and everything else seems to work normally. Am I missing something simple here? Thanks, Brock.
    Do you have the Carpe Control app, if not please install it and follow instructions.
    Do you by any chance use the Software Keyboard app from Microsoft? That keyboard is garbage and causes a lot of issues.
    What is your system language?
    brock
    I do have the carpe control app. I’ve looked through settings on that app as well as DMD2, and couldn’t find any setting that related to zooming on the map page.
    I do have the Microsoft keyboard app. I’ll remove that and re-test when I get a moment.
    My phone is in English – is that what you mean?
    I’ll report back when I have a chance to test the removal of the Microsoft keyboard app.
    Thanks for you help!
    Brock.
    #806
    I do have the carpe control app. I’ve looked through settings on that app as well as DMD2, and couldn’t find any setting that related to zooming on the map page. I do have the Microsoft keyboard app. I’ll remove that and re-test when I get a moment. My phone is in English – is that what you mean? I’ll report back when I have a chance to test the removal of the Microsoft keyboard app. Thanks for you help! Brock.
    Almost sure the issue is being caused by the Microsoft Keyboard app, we did have another user with the same problem and the culprit was indeed Microsoft Keyboard… god knows what its doing to be able to cause such issue.
    brock
    An update as promised.
    I uninstalled the Microsoft keyboard and connected the Bluetooth controller  and straight away it worked perfectly. Zoom in and out in map view is now fixed.
    Thanks very much for you help, great customer service.
    Thanks again, Brock.
    #830
    fsackx
    Hi, I have the same issue, zoom in is not working with carpe controller.
    DMD2 and carpe controller app installed on a Samsung Active 2 tab.
    I can’t see any Microsoft Keyboard app (and I don’t understand why I would have a Microsoft app installed on an Android device …)
    Please help.
    #841
    Hi, I have the same issue, zoom in is not working with carpe controller. DMD2 and carpe controller app installed on a Samsung Active 2 tab. I can’t see any Microsoft Keyboard app (and I don’t understand why I would have a Microsoft app installed on an Android device …) Please help.
    Until we figure out whats causing this I would recommend installing Google Keyboard and make it your default software keyboard.
    A) Because its the best
    B) Because some keyboard apps are doing some weird key intercept and replace… which is fishy as hell
    Tomppa65
    Carpe Adventure controller issues.
    Because I am so happy with DMD2 beta I bought the controller. DMD2 is working with it very good. Osmand+ is working only in portrait mode with all functions. In landscape mode (can not install it on the bike in portrait) only zooming is working. In google maps I have nearly no function. I am on the latest firmware 3.0 and I do not have any Microsoft keyboard installed. Anything I can do to make Osmand and Maps work??
    Regards
    Thomas
    • This reply was modified 1 year, 11 months ago by Tomppa65.
    #3349
    Mr DVS 2U
    <p style=”text-align: left;”>I registered to post up that this is still an issue.</p>
    I couldn’t get the zoom out button to be recognized in the Carpe Iter Controller app.
    I found this thread and uninstalled Microsoft SwiftKey Keyboard and boom no more issue.
    #33381
    JD
    I have the same zoom issue on DMD2 App. My setup includes Samsung Galaxy Tab Active 3, DMD2 and Carpe Controller (including Carpe Controller app).
    Only keyboard installed is Samsung keyboard (default), and system language is English. No MS keyboard or any other keyboard variations installed.
    zoom works fine on other navigation app’s mapping, just not DMD2 mapping.
    I’ve tried installing GBoard (Google keyboard) to identify if such resolves the issue, but it does not. I also tried different tablet hardware; same issue.
    all updates (both application and OS level) are applied.
    Grateful for any advice on resolve.
    Update: found fix:
    Go to ‘Remote Controller Settings’ within main DMD2 Settings menu. Program Carpe controller button to zoom functions, by selecting zoom function, then pressing controller button that you wish to use for the particular zoom function.
    Hope this helps others.
    • This reply was modified 1 month, 2 weeks ago by JD.
