  • #34106
    TR42
    Can I connect the 865x tablet via it’s USB port to my computer, to have it been seen as just another drive, access the SD card, load and manage my .gpx and other files that way?
    Or do I have to pull the SD card from the unit, connect it to my computer directly with an SD card reader every time, to manage files on it that way?
    #34109
    sonwon
    Google Drive is the easy thing.
    #34110
    Guzzist
    you can insert an SC-Card into T865-X if it switched off. Later, switch on and connect via USB cable to PC. Then you need to allow data connection type at T865-X for USB connection. Then T865-X, and inserted SD-Card will be detected at PC as additional device/drive.
    Now you can copy, move, delete files at T865-X.
    #34112
    TR42
    Thanks to you both. I still do things old school. Have never messed with Google Drive or anything cloud based.
