Viewing 10 posts - 1 through 10 (of 14 total)
  • #5667
    Jan D
    He all,
    somehow, I managed to have some files in the download queue that are not going to be finished. Those are blocking the ability to download any other map, plus the icon is showing as an overlay.
    How can I delete the queue? Restarting DMD2 and the device does not help in this. My device is a DMD-T665 with the latest available DMD2 version (3.00065).
    I’m not sure what and how to resolve this.
    greetings
    Jan
    #7262
    Nick
    I have the same Jan.
    Did you work out a solution?
    #7304
    Jan D
    The solution was a bit strange:
    – uncheck all maps
    – switch from SD Storage to internal
    – restart
    – switch from internal to SD Storage
    – check the maps again for download
    I found that by – ok, let me revert to what I have done and start new.
    #7327
    How is the SD Card formatted? That sounds like what can happen when you use it formatted as “Expanded Internal Memory”.
    The best and safest way is format the SD Card as “Removable Storage” and then select “Use SD Card for Storage” option.
    Jan D
    He João,
    I’m not sure how that is formatted, but did reformat in the device and will check –
    Thank you for this wonderful product!
    #7766
    Timo
    Hello,
    Carpe Iter V4B; DMD2 v2.77
    I have a similar problem.
    I can’t download any maps at all.
    After following the procedure here, I still can’t download.
    I can click on the map, the download starts, but nothing happens.
    If I uninstall and reinstall the app, do I need the key?
    Where can I get it? There is no key stored in my settings here.
    Thanks for the help.
    Greetings, Timo
    #10593
    Joshua
    It is clear that your download queue is full of incomplete files, blocking more downloads. The overlay icon may indicate a blockage or error. Try deleting the stuck downloads or restarting the program to remedy the problem and free up the queue for fresh map downloads.
    #21220
    BJHawker
    Hi everyone, same problem here.
    @joshua : How do you clear the stuck downloads ?
    #21222
    Timo
    Version?
    i did. an Update. After that, everything works Fine.
    #21794
    BJHawker
    Sorry for my late answer, I waited for an udate to be installed.
    So I installed the 3.00149 and, unfortunatly, nothing changed.
    I saw some files named dmd2_downloader_database* in the backup folder. I wonder that some databases are used somwhere to handled the downloads.
    Is there a way to use them ?
