#9221
MotoNavAdventure
Is there actually already a voltage converter that makes it possible to connect the DMD-T665 to a Remote 1 via cable, ensuring both the power supply and the signal transmission? Or is there a pre-configured split cable that would enable this function, similar to the splitter for the T865? As an end customer, it is a bit annoying for me that there is a splitter for the DMD-T865, but for the DMd-T665 the data line wires have to be soldered by hand. Is an end customer-friendly solution on the horizon?
DMD - Top Navigations and Motorcycle Accessories from Portugal - MotoNavAdventure, your Swiss Reseller
