#828
Hi there! Recently I discovered DMD2 and it’s amazing! Congratulations to the team that develop it! My setup is based on a Motorola Moto G7 plus smartphone and I’m facing the following problem: the temperature indicator isn’t correct. Follow an example where DMD2 show 32°C when the ambiental temperature is 26°C. I assume that DMD2 get this data from some smartphone sensor so there’s a way to adjust this (like a calibration) to make this indicator show a value approximated with an external/ambient temperature? Thanks in advance and greetings from Brazil!
Hello!
That is the battery temperature. In the next update we will be removing it and in the future add option for ambient temperature and actual weather data temperature.
