15 July 2024 at 9:58 am
#7723
Can I put several waypoints together in a single gpx file without a route being built between them? Any current online solution I should use?
Lets be DARK LORDS INQUISITOR OVERLORDS about GPX terms. We need to stop using the wrong GPX terms!
There is no other alternative! A waypoint is NEVER routed. A Waypoint is a pin on the map, it serves no other purpose!!
A GPX can have tracks with track points that are connected to draw lines on the map -> no routing
A GPX can have routes with route points that will be connected using turn by turn calculation -> routing
A GPX can have waypoints which are just markers with information.
