#6599
Reviving this thread, I too am having problems getting DMD2 to save maps to the sdcard instead of internal memory. Just purchased a DMD-T665 and would like to know if there’s either a command somewhere to store maps to sdcard or a menu for making this happen.
I notice that on my sdcard, there is a directory created by DMD2 for maps, but there’s no maps that I’ve downloaded in that directory:
I know the directory is working properly, as I’ve created a GPX directory and the DMD2 is able to open my gpx files from there, but the maps directory is empty and files are stored somewhere on the phone’s internal drive. Would it be possible to allow sdcard storage functions for DMD2?
How did you format the SD Card?
Did you format the SD Card as Extended Internal Memory? -> VERY dangerous setting as it can easily mess up your system. But if you insist on using this method you need to start DMD2 – Go to Global Settings (Cog Wheel in bottom menu) – Disable the “Use SD Card for Storage” setting -> restart DMD2
Did you format the SD Card as Removable Storage? -> If so you need to -> Go to Global Settings (Cog Wheel in bottom menu) – Enable the “Use SD Card for Storage” setting
