14 May 2024 at 3:43 pm
#5686
The available settings are accessible in “Map Layers” where you can setup Scale & Visibility which allows you to adjust the sizes (scale in relation to zoom) that will allow you to get a better line width for the different roads.
To what concerns the looks of the map you can select between the road and off-road styles – this is available in “Map Type & Style” and when you enable the off-road map then you can adjust it more in “Topo Advanced Options” where you will find the “High Contrast Mode”
That is most of it…
More option would need to be implemented.
Even if you manually adjust the theme file (edit it in the PC) every-time you start the app it gets overwritten.
