Hello John,
thank you for your quick reaction🙏
As i wrote, i updated the Ci Pad to Android 11. So my BT settings are deleted.
I only use Carpe ADV Controler and the M1 OBD Scanner ( all OEM Instruments are dismantled )
From the day I received the Ci Pad and the ADV Controler from Thork Racing last January all works fine.
So now after the Update to A11 the 2 BT devices had to be paired again …
The ADV Controler first, paired and then shown in the BT List as connected.
Second the M1 OBD Scanner … paired , shown in the BT List for 1 second as connected , than he falls down in „Formaly“ connected.
Of course I had also chosen the M1 in DMD Settings before. No BT Connection with DMD was possible.
So after a sleepless Night the only thing i changed is : I switched DMD from „Start App“ to Standard.
And what should i say … all works properly … The work around now : I start the CiPad, I start manualy the DMD App, I switch on Ignition > both BT Devices connect themselves in a very qiuck time.
I think my bike and I are prepaired for Season 2024 … 🙏
John, perhaps you find the Time to give us the wheel sensor function also back 😂😇
Many greetings
