DMD2 – 3.00029 & 30:
– Road names will not use Google Geocoder on devices without Play Store
– New widget indicator “Compass Cardinal” with text cardinals
– DMD-T devices setting in Global Settings to choose “Run while screen is off – enable / disable”
– Added exit dialog with option to fully exit app or send it to background
– Fixed a case where the insert coordinates dialog would not go be closed when exiting the map
– Improved some dialogs to respond to controller exit (long press B)
– Map Progress widget now shows road name
– Map Progress widget and Speed widget – If progress widget is visible in panels the speed widget will not show navigation instructions
– Removed progress bars from OBD indicators
