[quote quote=3813]Hello Joao .Its getting better and better. But in 26 there is a little bug in landscape the bottom menue disappears sometimes on start , when you calculate a route or other actions. When you then lock and unlock the screen it reappears. Funny[/quote]
Actually its probably because when you tap the top status bar you can toggle bottom menu visibility 🙂 Give it a try!
DMD2 – 3.00027 / 28:
– Improved Goole Maps URL sharing with reverse Geocode
– Map view now shows current road name – you can disable in map settings
– DMD2 can now be closed by BUTTONS app -> future DMD-T devices FW update
– DMD2 will now check for background location permission on DMD-T devices
– Other small improvements
DMD2 – 3.00025/6:
– Fixed a crash where GPX Track segments without points would cause app issues (although these should never exists they are a thing)
– Fixed a case of app crash when user inserts numbers in settings which are text only, now properly validates
– Added support for opening Google Maps URL types
