#3613
Paraendurist
Hello John
Can you please tell me why it is so difficult to fix the problem with the mapview. Its still not possible to keep the screen locked. If i lock it by pushing the button it opens up again after 20 seconds. I mentoned this and not me alone on several versions after 3.0. Why is it not possible to fix that.
Still it is not possiböe to make a route calculation out of a track i mentioned this about a month ago same is true for the addition of the tracks in a gpx file its still wrong. I dont mind if you regard these bugs as not on top of the list items, but when there is no feedback on this i dont need to be a beta tester any more. There is no use of testing when there is no feedback. As anybody else mentioned I do not see the progress because there is no change report since 3 updates. I appreciate your work but why did you change your behavior
