[quote quote=3227]Hi John, a question for you: I am trying to use road navigation but keep getting the error that a friend tells me would have been solved in the last update. It says “Calculation Error Error reading datafile E5_N45.rd5 I’m using the T865 with firmware version 2.99964. I have cleared the cache and restarted, that’s where I run out of IT knowledge 😅 Would you have any tips for this, massive rain here today so no riding in the woods alone,has the be 700 kms of road riding to get home sadly… Cheers![/quote]
That is related to a missing map file, delete the map file and download it again.
If the problem continues please let me know which country are your trying to route in.
Beta 2.99965:
– Improved many map pin icon sizes to adapt to screen dpi
– OBD – Voltage from dongle is not using ATRV command
– Altitude values are now displayed using MSL value
– Route calculation profiles improved
– Home Dashboard: Speed widget will now show route calculation instructions if any active navigation is present
– Common dialogs have been improved visually
– Minor button UI changes
– Map – Fixed yet another case where Sat Layer would be displayed over some track lines
– Fixed a crash in Android 14 when DMD2 would go into background/pause states
– Initial partial portrait support (in progress) – OBD View missing and Roadbook incomplete
