I created a small python scripts that will check all available PIDS on the motorcycle. This way you can see what will be available to you in DMD2 for your motocycle. On my motorcycle (Honda CRF 300L Rally) majority is not supported. I will try some custom and extended PIDS maybe I can find gear indicator which would be a nice feature. I’m hoping that developers will fix Voltage issue and add ATRV command for the ELM327 dongle owners.
You can download the script at: https://github.com/omadon/Moto_OBD2_Discovery
Below is the example from my bike:
C:\OBD2>python OBD_supported_features.py
Available serial ports:
1. \.\COM3
2. \.\COM4
3. \.\COM5
Enter desired serial: 2
———– Honda ———– CRF 300L Rally EU ———– VIN: MLHND16A6M50XXXXX ———-
Mode PID Active Description Value
00 ATI Yes ELM327 version string OBDII v1.5
00 ATRV Yes Voltage detected by OBD-II adapter 14.6 volt
01 00 Yes Supported PIDs [01-20] 01111100001111101100000000010001
01 20 Yes Supported PIDs [21-40] 10000000000000000000000000000001
01 40 Yes Supported PIDs [41-60] 10000000000000000000000000000000
09 00 Yes Supported PIDs [01-20] 0101010101000000000000000000000000000000
09 02 Yes Vehicle Identification Number bytearray(b’MLHND16A6M50XXXXX’)
03 Yes Get DTCs []
01 01 No Status since DTCs cleared not supported
01 02 Yes DTC that triggered the freeze frame (‘P0000’, ”)
01 03 Yes Fuel System Status (‘Open loop due to insufficient engine temperature’, ”)
01 04 Yes Calculated Engine Load 26.274509803921568 percent
01 05 Yes Engine Coolant Temperature 24 degree_Celsius
01 06 Yes Short Term Fuel Trim – Bank 1 0.0 percent
01 07 No Long Term Fuel Trim – Bank 1 not supported
01 08 No Short Term Fuel Trim – Bank 2 not supported
01 09 No Long Term Fuel Trim – Bank 2 not supported
01 0A No Fuel Pressure not supported
01 0B Yes Intake Manifold Pressure 47 kilopascal
01 0C Yes Engine RPM 2106.0 revolutions_per_minute
01 0D Yes Vehicle Speed 0.0 kilometer_per_hour
01 0E Yes Timing Advance 23.5 degree
01 0F Yes Intake Air Temp 22 degree_Celsius
01 10 No Air Flow Rate (MAF) not supported
01 11 Yes Throttle Position 10.196078431372548 percent
01 12 Yes Secondary Air Status Upstream
01 13 No O2 Sensors Present not supported
01 14 No O2: Bank 1 – Sensor 1 Voltage not supported
01 15 No O2: Bank 1 – Sensor 2 Voltage not supported
01 16 No O2: Bank 1 – Sensor 3 Voltage not supported
01 17 No O2: Bank 1 – Sensor 4 Voltage not supported
01 18 No O2: Bank 2 – Sensor 1 Voltage not supported
01 19 No O2: Bank 2 – Sensor 2 Voltage not supported
01 1A No O2: Bank 2 – Sensor 3 Voltage not supported
01 1B No O2: Bank 2 – Sensor 4 Voltage not supported
01 1C Yes OBD Standards Compliance not supported
01 1D No O2 Sensors Present (alternate) not supported
01 1E No Auxiliary input status (power take off) not supported
01 1F No Engine Run Time not supported
01 21 Yes Distance Traveled with MIL on 0.0 kilometer
01 22 No Fuel Rail Pressure (relative to vacuum) not supported
01 23 No Fuel Rail Pressure (direct inject) not supported
01 24 No 02 Sensor 1 WR Lambda Voltage not supported
01 25 No 02 Sensor 2 WR Lambda Voltage not supported
01 26 No 02 Sensor 3 WR Lambda Voltage not supported
01 27 No 02 Sensor 4 WR Lambda Voltage not supported
01 28 No 02 Sensor 5 WR Lambda Voltage not supported
01 29 No 02 Sensor 6 WR Lambda Voltage not supported
01 2A No 02 Sensor 7 WR Lambda Voltage not supported
01 2B No 02 Sensor 8 WR Lambda Voltage not supported
01 2C No Commanded EGR not supported
01 2D No EGR Error not supported
01 2E No Commanded Evaporative Purge not supported
01 2F No Fuel Level Input not supported
01 30 No Number of warm-ups since codes cleared not supported
01 31 No Distance traveled since codes cleared not supported
01 32 No Evaporative system vapor pressure not supported
01 33 No Barometric Pressure not supported
01 34 No 02 Sensor 1 WR Lambda Current not supported
01 35 No 02 Sensor 2 WR Lambda Current not supported
01 36 No 02 Sensor 3 WR Lambda Current not supported
01 37 No 02 Sensor 4 WR Lambda Current not supported
01 38 No 02 Sensor 5 WR Lambda Current not supported
01 39 No 02 Sensor 6 WR Lambda Current not supported
01 3A No 02 Sensor 7 WR Lambda Current not supported
01 3B No 02 Sensor 8 WR Lambda Current not supported
01 3C No Catalyst Temperature: Bank 1 – Sensor 1 not supported
01 3D No Catalyst Temperature: Bank 2 – Sensor 1 not supported
01 3E No Catalyst Temperature: Bank 1 – Sensor 2 not supported
01 3F No Catalyst Temperature: Bank 2 – Sensor 2 not supported
01 41 Yes Monitor status this drive cycle False, 0, spark
01 42 No Control module voltage not supported
01 43 No Absolute load value not supported
01 44 No Commanded equivalence ratio not supported
01 45 No Relative throttle position not supported
01 46 No Ambient air temperature not supported
01 47 No Absolute throttle position B not supported
01 48 No Absolute throttle position C not supported
01 49 No Accelerator pedal position D not supported
01 4A No Accelerator pedal position E not supported
01 4B No Accelerator pedal position F not supported
01 4C No Commanded throttle actuator not supported
01 4D No Time run with MIL on not supported
01 4E No Time since trouble codes cleared not supported
01 4F No Various Max values not supported
01 50 No Maximum value for mass air flow sensor not supported
01 51 No Fuel Type not supported
01 52 No Ethanol Fuel Percent not supported
01 53 No Absolute Evap system Vapor Pressure not supported
01 54 No Evap system vapor pressure not supported
01 55 No Short term secondary O2 trim – Bank 1 not supported
01 56 No Long term secondary O2 trim – Bank 1 not supported
01 57 No Short term secondary O2 trim – Bank 2 not supported
01 58 No Long term secondary O2 trim – Bank 2 not supported
01 59 No Fuel rail pressure (absolute) not supported
01 5A No Relative accelerator pedal position not supported
01 5B No Hybrid battery pack remaining life not supported
01 5C No Engine oil temperature not supported
01 5D No Fuel injection timing not supported
01 5E No Engine fuel rate not supported
01 5F No Designed emission requirements not supported
09 01 No VIN Message Count not supported
09 03 No Calibration ID message count for PID 04 not supported
09 04 Yes Calibration ID bytearray(b’407′)
09 05 No CVN Message Count for PID 06 not supported
09 06 Yes Calibration Verification Numbers
This reply was modified 11 months, 1 week ago by
omadon.
