#2836
Paraendurist
Hello John
There must be a severe bug.
1. Whwn I am in Dmd2 on an aktive track and want to change anything like adding the next track changing colouramaking a used track invisible dmd2 crashes. Sometimes it has the changes made when you restart sometimes not.
2. The progression window on the right side in map mode will not reset automaticly any more. Its irrelevant whether you select one day 6 or 12 hours it just does not do it.You only can reset manualy.
I would like to be able to make the reset directly on the map view not only on the home screen. Cheers
