Beta 2.99936:
– New “Location Icon” options in the Map Layers manager
– You can now adjust location icon size
– You can now enable a show location accuracy circle around the location icon
– Fixed a crash when hiding the right panel widgets in the map view
– Fixed a case where swapping SD Cards on DMD-T devices would not recheck path
– Fixed a bug on the language switch (in the map view options) for the German map
– Completely redid Topo theme zoom levels for different road types (everything will be visible at lower zoom levels)
– Fixed a case where tunnels and bridges were not showing/hiding at the same zoom levels as the road to where it belonged
– Removed a series of unnecessary Runtime exceptions catch-trigger and converted them to log output
