[quote quote=2646]1. Most annoying: I use dark theme (in order to preserve battery), so from time to time app is switching back to the default light theme. After loading tracks, zooming out etc. It is not frequent, but it happened more than once (let’s say, about 5-10x in 10 days). Maybe, some kind of option(s) reset to default(s) bug? [/quote]
Sounds like you enabled sensor based theme, go to Global settings and set a theme manually like “Always Dark” otherwise it will change the theme according to the light sensor, which on some devices does not work that well.
[quote quote=2646]
2. On some tracks (for instance: Montenegro TET from TET app) from time to time touching points on the track does not result in bringing up the “Point position distances” window. After deleting the track and loading it again, it works as it should.
[/quote]
Checking this today.
[quote quote=2646]
3. In the “Point position distances” window, after clicking on “Track details” and than clicking on “Back” you are redirected to GPX dialogue, not back to Position distances (so, Back button should be context sensitive, not a “hard” link 🙂 Features that can be better:
[/quote]
Will fix this today.
[quote quote=2646]
1. Using routing icons on the route (for turns indications) directly on the map is counterproductive. It clogs up the map view to the point that it is almost unusable (6.7″ screen, it is maybe better on 8″+ tablets). Maybe to consider dropping turn icons altogether on the route as an option? Turn directions in route progress box is quite enough (at least in my opinion). Or, maybe showing only next 3 turns on the route (or something like that)? Showing every turn, including previous ones clogs map in urban scenarios very fast.
[/quote]
Agree its not that good on phone size devices, will work on this today
[quote quote=2646]
2. Dropping hospital symbols from the map will also be an improvement. I understand why they are there, but in my opinion it is also counterproductive, since it clogs map view in urban locations. 3. Saving waypoints on the track is massively needed 🙂
[/quote]
Will fix this today
[quote quote=2646]
4. Routing between two selected points (instead only from current location and one selected point) also!
[/quote]
Multi point nav calculation is coming soon, with it you will be able to route between as much and for any points you want.
[quote quote=2646]
5. Saving Routes as GPX to local storage is needed for offline alternatives planning. Would be helpful.
[/quote]
Not sure I understand this.
[quote quote=2646]
6. Is it possible to avoid Google Files as file manager? I think not for third parties app (Android feature), but in case you know some workaround, it would be perfect! Google Files has MANY problems, some of them VERY annoying (reset is needed) Conclusion: all listed above are small problems, really. DMD2 is already VERY good tool. And by good, I mean that dmd2 threatens to become the best tool in android ecosystem for enduro rider out there. With small improvements it can become good tool for enduro trip planning in offline and terrain conditions, which is huge for many of us! Keep up the good work and we’ll keep up to promote and support!
[/quote]
Not related to DMD2, you can use any file manager in Android and set it as default file manager, probably better to search for a YouTube video on how to change default file manager.
Thank you for all your suggestions!
