DMD2 beta installed to Galaxy Tab 2 (active) App loads and runs – App – moved to external SD card and runs Maps will not load to external SD card, and option to store externally is in the menu, but does not work. Forcing via dev option does not work either Net result is Tablet runs out of space to run programs
Same here seems it depends on regulation by Samsung. That’s the Reason why i have to skip the Beta
Now i have to wait for a solution or go with the Active Tap 3 or with the T865 but 550 at much more than a used 2 ( which runs with the older DMD2) or a used Active 3
Odd i can install the D2D app, and run the app from the External SD card
I can instally Spotify & all downloaded music 6+ Gb to the SD card and run it from there,
I can install copilot & maps on the SD card and run from there
Which suggests its not the tablet / OS that is the problem, more the app?
