13 July 2023 at 6:34 am
#2585
Ace Gant
[quote quote=2582]DMD2 beta installed to Galaxy Tab 2 (active) App loads and runs – App – moved to external SD card and runs Maps will not load to external SD card, and option to store externally is in the menu, but does not work. Forcing via dev option does not work either Net result is Tablet runs out of space to run programs[/quote]Same here seems it depends on regulation by Samsung. That’s the Reason why i have to skip the Beta 🙁 Now i have to wait for a solution or go with the Active Tap 3 or with the T865 but 550 at much more than a used 2 ( which runs with the older DMD2) or a used Active 3
