30 June 2023 at 2:45 pm
#2461
Beta 2.99928 released:
– Clock Widget available in the Home bottom slot
– New Time indicator in the GPS/OBD Sensors widget (available for home / roadbook / map)
– Route Planner – greatly reduced the chance of using a cycleway in the calculations
– Home Panels (Left and Right) now allow you to change position by tapping on the title
– Home Panels (Left and Right) now allow you to change position in loop with the same control, when it reaches then last or first position it will loop
– Roadbook – Totals and Partials decimal places now apply immediate
– Map View: when you enable the topo map theme the Advanced Topo Options menu entry is correctly placed under the Map Type & Style menu entry
