[quote quote=2342]Hello John Tested today the track Poi Search again. Unfortunately the Routine searches for all tracks which are loaded in the System regardeless wether they are aktivated or Not. IT IS irrelevant wether You chose one or all Tracks are Hidden IT searches anyway. So You are forced to load only the todays track. If You Plan a 3 week Journey this IS very problematic because You News an Archive system. I think your Intention was to search only for the crivated eg. Non Hidden Tracks. IT should be easy to Change that. When You follows my proposal to Cache search for planned Tracks there should be a Routine to exclude These Tracks from the search also and Just use the cashed search.[/quote]
Found and reproduced.
Im working on fixing this and adding the cached POI along the track.
