#2223
harupipapa
Certainly there is a setting for continuous key presses in the load book settings, F5 (button 1 of bar buttons) is valid. but This function is disabled for” F6″ and” F7″ (button 1 and button 2 of bar buttons). Upon inspection, the DMD Roadbook’s corresponds to button A “Keycode EQUALS” &” keycode A” is valid “F6 “is disabled corresponds to button B “keycode minus” &” keycode escape “&”keycode C” &” keycode Back” enabled “F7” is disabled Please check and fix.
You making it all confusing, there should be a specific firmware for that controller provided by the manufacturer. I have no idea why you are talking about key code C or key code minus, or key code escape… I will check it after tomorrow with the controller provided by the manufacturer with its firmware. DMD2 is not just about KeyCodes… its about correct key events and making sure DMD2 recognises the controller model.
Sorry for making things difficult.
I understand it works with some code to keep controllers compatible. (There are other conditions as well)
To understand if this issue is caused by controller side or DMD2 side.
I wanted to tell you that it works fine with other keycodes.
