[quote quote=2213]
Buttons are fully configurable in the Roadbook View settings (cog wheel in the roadbook view top right corner), you can literally set them to REPEAT or NOT, and even set the repeat speed![/quote]
Certainly there is a setting for continuous key presses in the load book settings,
F5 (button 1 of bar buttons) is valid.
but
This function is disabled for” F6″ and” F7″ (button 1 and button 2 of bar buttons).
Upon inspection, the DMD Roadbook’s
corresponds to button A
“Keycode EQUALS” &” keycode A” is valid
“F6 “is disabled
corresponds to button B
“keycode minus” &” keycode escape “&”keycode C” &” keycode Back” enabled
“F7” is disabled
Please check and fix.
This reply was modified 1 year, 3 months ago by
harupipapa.
