#2213
[quote quote=2196]Hi It looks like DMD2 is using a lot of power even when the screen us turned off/locked. Is it possible to make the app pause GPS when the screen is locked? Or maybe have an option where it goes to sleep when charging stops? BR Jesper[/quote]
It is not, the whole Location service gets stopped when you turn off the screen (no GPS use).
How did you measure the power consumptions?
[quote quote=2200]apparently The keycode F5 seems to support continuous presses. The keycodes F6 and F7 don’t seem to support continuous presses. in roadbook mode When working with a PDF, pressing the button scrolls only once. You have to press the button each time. It’s a pain to press the button every time you want to look ahead in the PDF. Is this the specification? I want continuous operation just by pressing a button can you fix it? bar button galaxy tab active3 latest beta[/quote]
