To exit panning mode long press the bottom button.
As reference:
First Round Button – Either works as “Enter” on a selection or toggles something in the current view
First Round Button Long Press – Always goes to Bottom Menu selection
Second Round Button – Increases something (depending on the selection), in the map Zooms In
Second Round Button Long Press – In the map view current starts the POI search dialog, but this will be user configurable soon
Third Round Button – Decreases something (depending on the selection), in the map it Zoom Out
Third Round Button – Usually BACK or CLOSE, in the map view if no dialog is visible it also does LOCK, this will also be user configurable soon
When everything is ready you will be able to select what each button does.
For today update we added an option to disable the map panning mode to return to the old mode.
