26 May 2023 at 6:54 am
#2049
Paraendurist
I tested the gpx conversion. IT works but without a possibility to correct the result there IS Not so much use. The Route drives circles and squares and rectangles and drives Back and forth. This was based on a 365 km perfectly to a map Adapter track which Always Drive in the correct direction of roundabouts and so on .Calculation was based on Mixed and avoid tolls and highways.it used highways anyway.
