17 May 2023 at 2:04 pm
#1882
Would be great if you could fix the manual setting of the tilt mode (or even only on= max tilt) for the current direction up map mode – don‘t really see why you would need a tilt for the other two modes of the map, and I personally don‘t see a big advantage of different nap tilts other than off or max.
I think I understood this one, you are saying that manually adjusting the tilt should only be available when the Direction Up mode is enabled. Correct? If so I do agree! Will look into that.
