#1500
Abyss79
Test on the last Beta version are running every day.
I notice that if you have ODB connected if you are following a track you will get under the progress bar the estimate left time to the last point.
This is very good, but I notice that not always this value came up.
If ODB is not connect there is no time
If is connected some time you have to move between MAPS, Home and ODB in order to get the value…
Probabily there are some condition that make the value visible or not…. do you have the same issue?
Thanks
Christian
