#1477
Hi John Possible bug: It looks like Map view is missing as an option on the right widget on the home screen. I don’t know if this is intentional. v2.992 BR Jesper
Map View is indeed limited to the left panel because it can only be loaded in one place and im too lazzy to make the required extra work to check if its already loaded and show you a message saying it is already loaded and all the other require work to handle all that.
