#1286
Ejj75
“will check the widget change, does that mean you can setup the widget once but it crashes only when its set and you want to change it to something else?”
I have installed Widgets with an earlier DMD2 beta version. I updated DMD2 to version 2.89. Already installed Widgets work well. If I try to change Widgets, DMD2 shuts down when the widget selection should open.
Finally I completely reinstalled the 2.89 beta version, after this I can’t install any widgets.
Earlier installed widget
  • This reply was modified 1 year, 10 months ago by Ejj75.
