21 February 2023 at 6:31 pm
#1268
marius.mihasan
2.89 No more this connection/stuck issue. “Wake up Samsung Tab and DMD2 is on the screen. ODBlink wakes up automatically and BT connection seems to be ok. Switch ignition on, start engine. RMP shows 4163, voltage 0.0, coolant 25c, throtle 25%. Values are every time same and stuck, no change.” If I try to change Android External Widget it crashes DMD2.
Same issue on my no-name Chinese obd dongle. It can connect to the dongle, but its stuck at exactly the same values – RPM shows 4163, voltage 0.0, coolant 25c, throtle 25%.
