Version 2.85 (13/02/2023)
– Sensors Widget now includes Reset and Invisible option – In the map view to toggle invisible slots you need to long press the small button on top that toggles widgets visibility
– Minor UI improvements
– Added Map Long Press dialog (for now just for external navigation start and sharing that location with other apps like before)
– Added quick location map update on start (used until filtered location are accepted)
– Improved some location filter rules for calculation operations
– Improved map pause and resume logic (between map view and map widget)
– Fixed a bug where waypoint were being displayed even after you hidden the GPX file
– Further improved CARPE Tab filtering
