Setup: DMD2 Beta2.84 + Samsung Galaxy Active 3 + ODBlink LX + Yamaha Tracer 9GT
1. Use case: ODB reading issue.
I Start point: ODBlink LX in sleep mode. Ignition off. Samsung tab in sleep.
II Wake up Samsung Tab and DMD2 is on the screen. ODBlink wakes up automatically and BT connection seems to be ok. Switch ignition on, start engine. RMP shows 4163, voltage 0.0, coolant 25c, throtle 25%. Values are every time same and stuck, no change.
If I turn off the engine and restart again everything works smoothly and the values change (rpm, voltage etc.). Or if I reboot DMD2 ODB reading start works also.
This happened only if ODBlink is on sleep mode in the begining.
2. 3D view of the map worked just after installing Beta2.84, but stopped working yesterday. (the license was ordered with DMD2 normal version about a week ago).
